We have done several 50-100 device installs with GenI devices without any problems. We have a few installs over the 100 device mark with the largest going over 200 devices at Christmas time every year. The problems that I have had with UPB GenI devices are not a result of device count in any way, but more of the Home's wiring topology and noise. We have installed noise filters on some fluorescents or just replaced the fixture when the noise maker was on the same circuit as the Upb device which has been easy enough. Our 200 hundred device install is a very renovated, added on, and updated home with multiple sub panels, breaker boxes, and etc. After all noise was removed by changing two light fixtures, five inverting phase couplers had to be installed in 5 of the 12 panels and in one panel we moved some breakers for a couple of loads to make it all work. This install is all GenI and is well over a year old and has never had a reported miss. This Home has a HAI panel and was started with HLC programming and finished up with Upstart. When looking at signal levels in upstart it is very scary looking; missing devices, low signal strengths, and etc. BUT works like a charm. With that being said GENII devices seem to be the answer to UPB short comings. Before Christmas I was programming 5 modules and none of them could be found and I noticed a ton of noise, I pulled a case of GenII modules off the truck and they worked like a charm, I didn't even bother looking for the noise. So maybe the noise issue could be a thing of the past? As far a poor wiring topology and signal attenuation, while I haven’t had to install one the new repeaters they should eliminate that problem. Speed on the GenII stuff is excellent, I took my first dimmer back out because I couldn't get it in setup, Duhhhh you need double tap a lot faster. One last thing is power conditioners, some are not PLC friendly. Good luck
