TonyStewart
sbwright, you're on the right track here.
Where possible i would join the polling loop wires (white and yellow on the switches i believe) together where you have multiple switches in the same gangbox/location. This will cut down dramtically on the total length of your communication bus. I don't the length is a significant issue for the On/Common/Off wires, some voltage drop may occur, but i doubt it woudl be a real issue since there is no reall communication going on there.
I believe that the hubs essentially have a signal amp in them (powered by the 12v) and that the output of that amp is shared across all 9 ports, so it's not 500ft per port, but the total that counts. I hope to get this confirmed somehow..
Between the lot of us i think we are starting to have a pretty good understanding of this system and it's probably a good idea to get the 'designs' vetted by the group before jumping in and spending $$$$.
I havent' messed with my ALC install (12 active switches or so at this time with 6 NIB) in a few months but need to pick this up again to get some more things automated. Anybody hear from Tony Stewart lately?
For Broconne's answer #2 I am assuming that you either have mutiple switches daisychained and connected to each of the 9 ports on the branch hub, you cascade the branch hubs(4) to get the total of 31 puchdowns, or use the 66 blocks? But then again the document says the hub only supports 9 ALC addressable switches, makes me wonder if that is due to only having the 9 physical connection points, something doesn't add up here.
In post #6 the powerpoint slide indicates that the Branch Hub "Extends ALC branch cable additional 1000 feet(total 1500 feet)" this is not consistent with the other documentation and it is not clear as to:
1) Is the 1500' for the entire branch length.
2) Is it 1000' between the branch hub and dist module and 500' for the remaining switch wiring.
3) Strictly for the wiring between the branch hub and distribution module.
If the 1500' its for the whole branch wiring length that would be great but sounds to good to be true. As with you we need to know the right answer before proceeding.
According to this section of the ALC/Onq Technical Guide any single switch should not be greater than 500' from the interface. Sounds like in a homerun installation as long as each switch individually connected to a Branch Hub or Distribution Module with no longer than 500' of wire would be acceptable
Anyone with a current setup and a spool with 500' of wire up to the challenge???
I am here guys. I have been very busy and traveling a good bit. Yes the hubs have amplification, opto isolation and signal buffering/conditioning. While it is rare that electrical noise is coupled into low voltage wiring it does happen. I have seen a number of times when powered hubs saved an install in this regard.
See my other post about the 9 ALC limit for more details. A quick summary is that any one 9 branch hub can support up to 31 devices.
As for the cable length limits. 1500 feet is pushing it and I don't recommend it. The documentation is not clear in this regard. So let me tell you my take and my experience.
Put a hub no farther away than 500 feet from the controller. Then ALL OF THE ALC CABLE RUNS from the hub to the switches must not exceed a total of 500 feet.
Example: 9 runs of 75 feet would total 625 and would be out of spec!
I have visited a number of installs where longer cable runs have been used and problems existed. Things like slow response (or missed signals) can result. This is rare as ALC is tough. But if your luck is like some of mine, your install will be the one that misbehaves. I admit that I have seen longer runs work with no issues. But it's a gamble!
A 66 block has no noise immunity, isolation or amplification. For a very small install, it's a good idea and an excellent way to lower costs. Just be careful with distances and noise from AC wiring.
Tony
