Hi Guys, after many many months, I am just about ready to turn on my ALC system. I have 158 switches (99 loads and 59 AUXes) on 4 branches wired through 12 branch hubs. Each switch has its own CAT5 wired into the box and covered with insulating heat shrink tubing to satisfy the local inspector (see pic).
I have finished all of the punch downs, and I'm anxious to start testing but I have not powered the HLC yet. The electrician has about half of the switches installed, and one of them is actually connected to a light that works! This particular light has one AUX which also controls it. So far, the LOAD switch works great, but the AUX switch does not work well. The AUX will turn the light on, but not off. Also, it doesn't seem to be as responsive as the LOAD switch. My expectation was that the behavior of the AUX switch is indistinguishable from the behavior of the LOAD switch. Can you confirm this is correct? As a test I grabbed an AUX which has not been installed, and use my meter to test the wiring. I found that ON worked great (and had a nice tactile click), but OFF did not work well. If I pushed hard enough the circuit would close, but there was no tactile click. Do you think my AUX switches are defective?
Also, I am trying to develop a turn-on/test strategy. My system has no scene switches, and will ultimately controlled by my CQC and its touchscreens. My CQC system is not installed yet, and I'm not sure its the best platform for debugging my ALC communication network. Do you know of any other software I can use? Perhaps I can just use HyperTerminal and send some kind of interrogate command. Then I could wire each hub individually to verify LOAD switch communications...
Thanks -- Bob
Thanks -- Bob
