asteinmetz
Excuse this duplicate post as this is also part of a message in my HA progress thread.
I have six Aprilaire 8870 stats. All work fine on a standalone basis. So now I have to get them talking to the Elk (and whatever future HA controller I use). I have the distribution panel and protocol adapter wired in. The protocol adapter converts the RS485 to RS232 that the elk serial interface uses. I hooked them up to the elk per the elk instructions and got nuthin'. So I take a step back and use the Aprilaire hookup instructions which tell you to get a dumb terminal talking to the 'stats before hooking it up further. I plug the RS232 cable from the adapter into my trusty Linux box and fire up gtkterm. I use the default protocol spec of 8N1, Echo on, at 9600 BAUD (remember when that was a FAST modem?). Nuthin'. The docs say I should see the RS232 RX and RS485 TX lights flash when I type in the terminal window. Nope. There is one tantalizing clue. When I send a <BREAK> to the adapter the appropriate lights do flash, so the adapter isn't quite deaf. The Aprilaire docs say "consult a computer professional" if things don't go well. The "Geek Squad" could solve this, I'm sure. Thanks.
  Thanks.
 Thanks.
  Thanks.
