AceCannon
The strike happened about 2-3 weeks ago.  Damage:
1-Elk M1G main control, "phone fault", noise on line whenever Elk is plugged into the RJ31X jack, control will not dial out.
2-No ALC devices can be controlled via the ELK-ALC interface
3-No comm with any of the four Aprilaire stats
Repairs:
1-So today I replaced the main control, found the XEP on the network, upgraded the control firmware, enrolled without the ELK-ALC or M1XSP for the t-stats, did a SEND ALL from the RP2. The phone fault is fixed, dials out fine now. No noise on line.
2-I replaced the ALC-ELK interface, enrolled it without a problem, There is a slow pulse on the M1 light, just as it should be. The ALC-ELK will control the scene switch and ALC devices fine, I get normal ALC activity blinks, so the lighting controller aspects of the thing work. But no Elk-generated commands seem to function. No rules mentioning lights work. CQC works via the Elk driver for everything except the lighting.
3-Replaced the M1XSP, it enrolls fine, normal slow blink. T-stats still no workie. Am awaiting shipment of a new 8811 (protocol adapter) and 8818 (distribution module), so we'll see if that fixes this problem.
So I am stuck on #2 for now. I've tried a bunch of maneuvers to get things working again but kinda am at a loss now. Any advice would be appreciated!
Repairs:
