OK, I have an AprilAire 8870 and 8811 Protocol Adapter set up on my bench and simply cannot get the thermostat to respond to command from Hyperterminal.
1. Thermostat is powered with 24 VAC transformer and the only other connections to it are the (4) RS-485 Data bus wires going to the protocol adapter.
2. Thermostat poers up fine and I have set up the communications in same per instructions in manual.
When I send SN command from terminal, I get absolutely no response back from the thermostat. I do get a TX data ligh flashing on the 8811 and and the communications indicator on the thermostat flashes momentarily but it sends nothing back and I get no RX indicator on 8811.
The 8811 is the new type that has screw lugs instead of pigtails and I have checked and double checked the wiring which is straight through A- to A-, A+ to A+, B- to B-, and B+ to B+.
I can loop the data around at output of 8811 (without thermostat connected) and it will echo everything sent from terminal so I am pretty sure it is OK.
I just sent a 8870 back to dealer because of this problem and beginning to think I am doing something wrong somewhere. Does the thermostat need other wiring to work?
