O.K. A few things. As stated, with SA inverting phase couplers, you can add multiple ones to increase your signal, I use three. But this will only help when the "Other" phase is weak.
What you need is an isolator. These don't exist commercially as far as I know, but you can build one easy. It just so happens that I built one just yesterday. I didn't have a signal sucker, but rather a new Panasonic Inverter Microwave that generates so much noise, my nearby UPB lights fail to work.
O.K. the device. You will need a 100 uH +/-(Micro Henry) choke rated for the current of your load, and 10 mF (Micro Farad) AC capacitor rated for at least 180VAC. The caps are typically used to start motors or control the speed of ceiling fans, so they are easy to find. I got one at Home Depot in then ceiling fan area. The chokes are a bit tougher, since Radio Shack doesn't carry these anymore, but try eBay or Digikey. The value isn't critical, but it but be rated to handle more current than you will put through it. I used a 15 Amp model for my microwave. I built the entire thing in a plastic outlet box, with an outlet in front, and about 3 feet of heavy duty power cord. The choke goes in SERIES with the outlet on the hot side, and the capacitor goes across the outlet from hot to neutral. Oh, and a fuse is not a bad idea either. So you have just created a "low-pass" filter.
If you have no idea what I just said, as a technical friend to build one for you. Mine took maybe 20 minutes to build once I had the parts, and my microwave noise is completely gone.
