I think it would be a good idea to indicate if the HA software provides a web-based UI. Unfortunately, a Yes/No response would not adequately explain the capabilities.
For example, some HA software provides an Administrative web-interface ... that's a great feature for remote administration but may not be the UI you'd want to use on a daily basis. Others provide an API to create web-interfaces ... but it exposes only a subset of the program's capabilities.
The other "gotcha" is the belief that if it is "browser-based" it will run on all computers and operating systems. Not really. If it relies on an ActiveX object to do its magic, it means it will only run under Internet Exporer/Windows/PC. More than likely the ActiveX object will be constrained to a Windows PC device that has an Intel "8086 family" processor ... and won't run on a Windows Mobile device powered by some other processor.
I'll give you an example, I use Premise Home Control and it provides a web-based UI for the end-user (auto-generated). When using IE, you must register an ActiveX object (sysconnector) in order to acquire real-time updating of all devices ... meaning if someone turns on a device, its status is immediately updated in the browser ... the browser doesn't use polling ... the ActiveX object permits "subscribing" to a device's changes. Very slick!
You lose all of that magic if you try to use a device and/or browser that can't use ActiveX objects. BTW, this is also true for many IP cameras that rely on an ActiveX object to provide streaming video.
To get around the whole ActiveX issue, Premise provides something called a MiniBrowser web-interface that displays (many but not all) of your home's devices in a simplified manner for use on web-enabled phones, etc ... but you need to hit the Refresh button to update the on-screen status of all devices (i.e. you're back to polling).
So just indicating "Yes" to "Browser Interface?" doesn't give you the whole story ...
