felixrosbergen
Do you want the differential volume? If not then you just parallel the speaker of the amp and have them be a single zone.
what are you plannign for the occupancy sensing? A basic motion sensor is not going to do the trick.
There's many discussions about this on these forums, just wondered if you had selected a specific solution.
I sure hope you're going to be taking some serious time off after the move-in to instal all this gear...
Although it's all fun, making the 25th cat5 termination while the wife is yelling at you that dinner is gettign cold or whatever get's old...
On the occupancy sensing... a regular motion will defintely not do the trick unless you're willing to wildly waves your arms every x minutes to keep the lights on.
I was surprise at how insensitive my Bosch bluelight pet imune motions were, but as insensitive as they were there was still not way for me to pass through the room without it seeing me. So i guess that makes for system with low false alarm probability but still good protection. I have 2 cats (1 18 lbs and 1 14 lbs) and in 2 months time haven't had a single false alarm except when my dumb ass walked downstairs without turning the alarm off.
A search for uccupancy sensors will yield you quite an array of products, but i haven't found any ELK/Automation ready ones out of the box. Most seem to be switching HB directly so you'd have to play with relays to make that all work.
Will this work with an Elk/HAI as an occupancy sensor? Low Voltage Occupancy Sensor
The spec sheet says to avoid heat sources within the field (Page 2, 'Note' on right) - would HVAC registers cause a problem?Will this work with an Elk/HAI as an occupancy sensor? Low Voltage Occupancy Sensor
I beleive you would need the CM-9-R model.
Front Porch -
Yay - Last room on the first floor.
H/A Equipment:
Motion Sensor
Doorbell
Security/Safety:
(1) Camera Pre-wire
Lighting/Fans:
There are three recessed lights on the porch. They are controlled by an ALC/OnQ switch on the foyer.
H/A Goals:
(1) Turn on the lights when motion detected or people approaching the door.
(2) Turn off lights when motion not sensed for a time period.
(3) Turn on the lights during sunset and off at a specified time.
(4) When doorbell is rung, pause SageTV (Using SageInfoPopup Plugin).
(5) When doorbell is rung, engage camera, switch CQC view to camera.
Questions:
Can I skip the motion pre-wire? Is the current motion sensing ability of an IP camera good enough?
The Front Porch Layout:
