Alright, trying to get some more info on wireing gauge on smokes. I did not plan right and installed 22/4 wire instead of 18/4. But I am seeing too that there is special red (fire resistant) sheating cable that may be required by code. We are in DC if that makes a difference. home is a townhouse, three floor, 1000sf per floor. There is basement rental that i want to zone separate, plus separate garage, also zone separate.
We already have a hardwired 120v smokes in each room of the house that was required by code. I am installing these smokes and thermal as a backup. and to be monitored in case we were not home and a fire broke out. I was looking at installing 1 per floor except on main living floor where i would put two. I want to add thermals in kitchen and furnace room on separate zones.
System is Elk M1G
Questions:
1. If this is installed as a secondary system, does it need to meet code in wiring?
2. I was told that in ordered to qualify for monitored discount on insurance, you had to have a smoke in each room of the house. true?
3. since my runs are so short, i was told 22/4 would be fine. What is the reason behind the 18AWG cable?
4. I had originally planned on homerunning each smoke so that it could be monitored on its original zone (may still need to do this for some areas (external garage, rental in basement). The Relay though takes up a good amount of power and would add to the panel load. are relays necessary?
5. DELInstallations had recommended just going with a 2 wire smoke install (I could do this for the main house). Are there any legal/code issues with doubling up the 22/4 cable?
6. Lastly, how do you calculate load with 2 or 4 wire configurations? Does one use less than other?
Appologies for restarting a new thread, but my last one was hijacked.
thanks
System is Elk M1G
Questions:
thanks
