CAI_Support
Tim,
We keep running the test board and monitor it. we want to duplicate the problem, then we can fix it for you.
In our lab, our power supplies are 12V10A and 12V30A power supplies. When we running long term test, we adjust the pot on the switching power supply to lower it to 11V. some can be lowered to 10V. Our power main to the lab is by a 48V battery backup 5000W DC/AC UPS. We plan to add solar panel charger to charge the battery during the day in the near future.
If you search "12V switch power supply " on eBay, you can find a lot of those from 3A, 10A, 20A lab power supply. Most of them has a little pot for adjusting output voltage. Most 12V power supply can be reliably adjusted to 11V, some of them can be adjusted to 10V. Most 9V power supply is power cube kind of supply that is less reliable than those lab power supply.
I am not saying your power supply caused problem. But a lot of problems were caused by the power. Since your power was working fine before, lets keep working on it, till we find the cause for it.
