fcwilt
Hi,
I've got a HAI OmniPro2 installed in my daughters home. It has the most recent firmware. It is configured for UPB lighting (some HAI devices, some SA devices) using the HLC scheme.
All works fine (normally).
One of the "rooms" is used for the outside flood lights (4 SA dimmer devices, 1 HAI relay device, 1 HAI room controller device). All of these devices are programmed with the standard ON, OFF, A, B, C, D scenes. The OFF scene is configured to set all devices to 0% as you might expect.
Here is the strange problem.
Twice in the last year my daughter has called me to say the flood lights will not turn off. I've gone over to her house and sure enough the OFF scene is turning the floods ON. Using UPSTART I have verified the entire UPB network. All devices are correct EXCEPT for the five flood light devices. For these five devices the OFF scene setting has somehow changed from 0% to 100%.
No other settings on any other UPB devices have changed - not a one - only these five devices - only the OFF scene - both times.
I am baffled, totally baffled.
Any ideas?
Thanks!
Any ideas?
Thanks!
