Desert_AIP
Does anybody know if the OmniTouch Pro executable will run on Raspberry Pi running Windows 10?
			 le:RemUnknown_QueryInterface No interface for iid {000000XX-0000-0000-X000-0000000000XX}
le:RemUnknown_QueryInterface No interface for iid {000000XX-0000-0000-X000-0000000000XX}This error indicates that the NetFramework method executed was not implemented in Mono. IOW, the method was "stubbed out". The method was named but the body of the method has no code to implement. So, by default, the method threw the NotImplementedException.HAI OmniTouchPro Version: 1.0.2.117
System.NotImplementedException: The method or operation is not implemented.
at System.Management.ManagementClass..ctor (System.String path) <0x412c3020 + 0x00023> in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Management.ManagementClass:.ctor (string)
at HAI_Shared.x0a89158ade776e38._x332506311d9db4ba (System.String x4ca53a5f35535999, System.String x4173f3c26c5922af) <0x412c2c80 + 0x00073> in <filename unknown>:0
wine Snap-Link.exe
fixmele:RemUnknown_QueryInterface No interface for iid {000000XX-0000-0000-X000-0000000000XX}
fixme:winsock:WSACancelAsyncRequest ((nil)),stub
