I just downloaded the latest Nuvo Configurator software v2.66.  I was experiencing the "9:85" time display problem and Nuvo fixed it in this release.  However, in the revision notes I also noticed that it says the Grand Concerto control pads can now be used with the Essentia E6G systems.  I know this is a question I've seen asked on occasion so I wanted to report it in case any Essentia E6G owners have interest in upgrading to the larger control pad.  I'm also copying the full revision notes below for reference.
NV-I8G & NV-E6G Configurator
Programming software used to create configurations for the NV-I8G (Grand Concerto) and NV-E6G (Essentia G)
Current Revision v2.66
Note: I8G & E6G Configurator 2.65->2.66
- Fixed automatic .NET Framework 1.1 installation
- Fixed "Invalid Hex Data" error message
- Includes most recent firmware
Tuner Configurator 1.13->1.14
I8GMPU/E6GMPU 2.65->2.66
- Enable use of I8GCP on E6G
- Fixed CP Brightness changed when time changed
- Fixed Mute/DND indicators
- Fixed Master zone not muting when volume ramped down by slave
- Fixed NV-MP causing time to be displayed as 9:85 on CP under some conditions
- Fixed pushing multiple buttons causing CP to think a button is still held
I8GCP/E6GCP 2.65->2.66
- Fixed brightness set to highest after self test
- Fixed "Loading..." displayed when adding iPod playlist to Favorites
- Fixed timeout when entering Sirius lock code
RIPS/WIPS 1.63->1.64
- Fixed iPod sometimes in stop mode instead of pause when battery is dead
- Added Play button support to menus
T2DAB 1.26->1.29
- Fixed quick scan lockup when no DAB present
- Improved AM/FM & RDS display on E6G CP
- Fixed DAB unavailable after power up
- Disabled front panel buttons when tuner is off
- Improved DAB display on E6G CP
T2SIR/T2FAM/RVSIR 1.17->1.18
- Fixed tune/seek up/down serial commands while in preset mode
T2DAB 1.26->1.29
