The red/white should connect to hot. I expected it not to work, but was really hoping I could be proved wrong. I can't run an additional conductor... At least the picture will show others what WON'T work with these switches so they can save their frustration for some other HA project.
panamanian- any thoughts?
Hello....
One thing we have to remember when it comes to electrical, do not be fooled by colors.
The NEC (National Electrical Code) has some stipulations when it comes to color coding. Neutral could be white for 120 volts and gray for over 208 volts. Hot could be black, red, blue for systems under 208 Volts an brown, orange and yellow for systems over 208 Volts.
The key element is to remember that electricity flows from your hot to your neutral regardless of the color, the internal copper wire doesn't know what color insulation it has.
In other words you analyze your wiring by understanding how that electricity is gonna flow to your components. There is an instance in the code that allows a white wire to be a "switch leg" so if someone looks at a box with a white and a black connected to a switch you will be scratching your head since a switch doesnt use a neutral, but what you didnt know is that the white wire is simply breaking the flow of electricity coming from the black wire and when you flip the switch the white one carries it to the light.
Now that being said, in order to help you I need to know a few things.
1)The picture you posted with the boxes and the switches, is that your current configuration right now or that is how you are expecting to wire it ?
2)I need to know the model of both master and auxiliary GE switches
3) the other diagram you showed was a diagram to have a 4 way arrangement. are you trying to do 4-way or 3 way?
A 4 way circuit is technically two (2) three (3) way switches and a four (4) way switch in between.
In the GE diagram that you posted im gonna explain how it works.
1) the ground (green) wire from each switch simply connects to your bare coper inside each box, thats for safety purposes.
2) the neutral wire coming from your feed or supply will connect to both your master switch white wire and the neutral that goes to the light. This neutral is the return path of your electricity flow when it goes across your load (light) back to the source (electrical panel)
3) the blue wire in your master switch will connect to your switch leg (regardless of color) that goes to the light. This wire carries the electricity to your light when any of the switches are pressed. In other words the master switch is the only one that controls when that electricity flows or not to the light.
4) every switch master or auxiliary has a black (hot) wire. this wire when connected to your feed or supply hot wire will simply power the internal circuitry of your switches, without it your switches cant do anything. the black wire doesnt need to go to any specific point or box in the circuit they are all in parallel.
So you simply need to connect each black wire from your switches to a wire that is connected the hot or supply wire.
5) the yellow wire is a control wire. when any of the switches are pressed that signal is sent to the others using this wire. The important thing here is that it doesnt matter if this wire goes directly between 2 switches or not. this wire could go from any switch box to another and from that one to the last switch box. Or they could all meet at any switch box.
In conclusion this 4 way GE diagram allows you control a light or lights from 3 locations without the use of travelers or dedicated wires from box to box.
the 2 auxiliary boxes only need 2 wires and a bare ground, the two wires could be black for hot and you could use the white as the yellow but for code compliance you will mark that white wire with yellow tape to identify it as being "not a neutral".
the problem is that you need to make sure that the white wire you are gonna mark as yellow is not connected to another neutral at the other end because it will be used for control.
the master box is gonna have a hot or feed connected to the hot terminal in your master switch. a switch leg coming from your light (it could be any color) that connects to your blue wire, a control wire (regardless of color) that connects to the yellow wire. And 2 neutral wires one will be the one coming from your light and the other the one that is going back to your electrical panel neutral bar, those you simply splice them together with a wire nut.
So let me know those 3 things i need to know so i can then make a diagram for your particular scenario.
I hope this helps
