ALC uses RAMP OVER TIME not fade. The difference is that with RAMP you can take hours to linearly and gradually bring a dimmer to desired setpoint. Fade is for UPB/X-10. If you want fast off/on press rocker twice. Otherwise it will go to the last bright level you set it to manually.
My ALC dimmers do this:
[From OFF] Single "On" takes it to preset value, in less than a second (it is NOT instant).  Double "On" takes it to full bright in less than a second.  Double "Off"
[From ON] Single "Off" takes it to full Off instantly.  Double "Off" takes it to Off in about 10 or more seconds.
I
really like the double off effect....very slowly taking the lights down.  (The amount of time it takes to do that MIGHT be the extended ramp setting).  But I hate having to press the button twice to get it...it seems like it should be the default (single press) action, instead of the instant jump to Off.
Is there anyway to configure that differently, Tony?  Looking at the documentation for the Scenetech software (I don't have the actual software), I didn't see anything that seemed to allow for configuring what happens when you hit the rocker once vs. twice.
 The double press is a function of the switch and not programming (although Scenetech may allow changes to the timing - not sure, will check). Double tap is a pretty standard feature for dimmers, even analog dimmers use this.
 Once you brighten the dimmer to a level and leave it there manually, a single press will take it to that level every time you press it once. Double tap will take it to full bright (just like all other brands and like analog dimmers). If you want full on to be a single press, then you manually brighten it to full on and a single press will take it to that level every time.
 If you are using automated scenes, then try this: use a scene to set a brighten level and then see what a manual single press will do. I will also try this and advise.
 Once upon a time, the ramp and fade for ALC was user accessible. But I am not sure of how to access that now. I will let you know the inside poop later, once I talk with OnQ.
TS
