I'm trying to use the contact side of a SPST relay for two purposes. One is to use as a NO or NC (no EOL resistor) input zone on an Elk M1G. The other is to use as input to a data logger. So each terminal of the relay contact would have one wire from the data logger and one wire from the M1G zone attached to it. The data logger can't handle any "outside" power on it's circuit. The diagram below supposedly shows how a diode can be used to keep voltage from getting to the data logger, but I don't fully understand it.
It looks like my setup is most like the "middle" option on the right side. I will effectively be connecting the data logger wires to the zone wires via the relay contact terminals. When the relay closes, the circuit will be complete.
So how do I know what "type" and "size" diode to use? I measure 13.7Vdc and 7.00mA on the M1G zone. I don't know yet if the data logger introduces any power on its wires. If it does, it's got to be a very small amount. The thing runs off a 3-Volt CR-2032 lithium battery that supposedly lasts eight months when used on a continuously closed relay (which is its highest battery draw state).
Ira
Ira
