wuench
I know there have been several threads recently on cameras but I would like to have a discussion on what software people are using, especially with Aircam.  I got my first one installed this weekend and it works pretty well.  I have had to order a wider lens, but other than that, the install was painless.
I installed AirVision onto a WinXP VM as my software. My intention was to use CQC to view the RTSP stream while home, and log in via the web when away or if necessary use eKeypad which has the aircam on the supported list. These are the things I have discovered:
1.) Playing an H.264 video stream in a browser is not possible by default. I ended up needing to embed a VLC player in an HTML page an serve it out.
2.) eKeypad's $49.99 video module is supposed to work with the Aircam's RTSP live stream, but I can't get it to work, on my local network or off. Emailed Jason waiting to hear back.
3.) To access AirVision's web server you have to forward not only the web port but TCP Port 843 and TCP/UDP Port 7080. It then works on my wifi, but not on AT&Ts 3G network, which appears to be blocking some of those ports. When are web developers ever going to learn, 80 and 443 on the internet, people, that's it, that's all you use.
So I am at that "COME ON" frustrated point you often get in the DIY world, when dealing with these products from developers and vendors who apparently have no common sense.
Does anyone have software they use that allows you to view live and recorded video remotely, reliably, securely that works with the AirCam (really just a standard H.264 over RTSP camera)? I would love to be able to view via web and especially on my IPhone...
