I contacted them, and they said 1 gallon per click is the best they can do. Model # he recommended for me was the DLJ7575C. I really was hoping for finer resolution, any other suggestions?The watermeters.com mulitjet 3/4" with 1 gal/count pulse (dry contact) had been selling for $99. I think you need to contat them to find the model with 0.1 gal/count. I do not recall the sampling rate of the ocelot, but seems to me it was 1 second (could be 1 millisecond). I'm just making the point that you need to do the math to make certain the pulse rate from the high resolution meter will not be too fast for the unit with which you are sampling. I know the DS2423 1-wire has a max spec of 50Hz.
We use a "Badger" brand water meter at work that has a head that is detachable from the meter. The head has a screw off lid with some gears and a reed switch(I think) inside. It is possible to replace the head and the meter seperately. There is no shaft between the meter and the head, the head is magnetically driven. The one we use provides 10 ppg. As best I remember the gears determine if it will be 1 ppg or 10 ppg. Ours is connected as an input to a programmable logic controller. I suspect this unit would be more expensive than some other available options. I never was a real fan of the gear arrangement, I always felt that the gears being a mechanical moving part create a potential failure point although the magnetic drive is pretty clever. I don't know if other meters are set up in this way or not since this is the only type I ever used except for a much more expensive meter we used for awhile that was more electronic in nature. It was used for handling water that had a lot of sand particles in it.
Brian
