Well, not much new work has been done since I pulled the cable. I got all of the surface mount contacts for the windows hooked up and tested, as well as all of the exterior doors. I needed to get the windows down so that the finish carpenters could put on the window stools, as some of my wire came through the bottom rather than the side. Getting all of this connected went pretty fast, and I didn't have one bad wire!! I also found a spray paint that matched the color of my vinyl windows perfectly, so it made the contacts blend in more.
The cabinets are being installed now, and I thought I would post a picture of the opening to the wiring closet. I'm pretty stoked about this little addition! The secret door will have cabinet doors on the bottom section, and adjustable shelves in the top section. In the picture with the door open, you can see the mudrings where all of the wire for the rack will come up from underneath the house. It is currently just bundled up under the house. I set up pull strings for each mud ring through a seperate 2" hole for each one in the bottom wall plate.
I am waiting for the painter now, after which I will be very busy installing all of the motions, smokes, heats, and other wall clutter. In addition, after the painter is in, I can start terminating wire in the rooms. In the meantime, I will be working on terminating all of my security wire to 66 blocks.
