Eric, Just wanted to double check before I go hooking up the 4 relay board I just got from you.
I have one of your 6 channel master hubs
From the RJ45 diagram on your site, it looks like there is +5volts on wire #2 and + 12volts DC on wire #7
I wasn't sure about the total current draw of the relay board.
Can your 6 channel master hub supply enough power to run the 4 relay board over about 125ft of cable?
