Question #3 - If I only measure one phase can I double it to get the power used by both phases?
The web page (and the first post) lists a lot of typical 240V loads (dryer, range, water heater) connected to a single Aux channel, so that would be my guess. It won't be entirely accurate using one CT if the load is 240/120.
Since my A/C only pulls 20A at 240 when running, I could use one of the Aux channels to monitor it. But I'm guessing (I didn't run out and check them yet) the AL wires are bigger than the 0.27 max I.D of the Micro CT. A CT with a larger opening, or since CT's are commodity items the ability to use whatever CT you want and set the specs for it.
What's the deal with the "optional dedicated potential transformer". Does this replace the wall wart or is it for something else?
According to the FAQ, the 1220 version samples 2000 times per second and averages the readings.
Same sampling rate for the 1240 on all channels?
How often can the unit be queried in real time?
What if there's a bug in the firmware? Is there any way to upgrade it?
For that matter, is there any detailed information available online about talking to these things? On the Brultech website I'm finding lots of graphics, a few references to packet lengths, but nothing technical.
I would like to point out that the information on the website is preliminary and not very descriptive at this point.
Originally, these Aux channels were to monitor current for the purpose of load detection. This has since changed from the original concept.
There are now five Aux channels each capable of monitoring a 120V or 240V load each. For any of the Aux channels, a second CT may be used for 120Vloads.
The Aux channel measure true power/energy and the measurements are processed by a dedicated processor ensuring that no processing power is taken from the main CH1/CH2 processor.
Each Aux channels are processed using approx 3KHz sampling rate, including the voltage sample.
The optional PT option is included to satisfy the request of some who wished to monitor the line voltage from 240V rather than only one phase.... probably rarely will be required...
As for the Micro-CTs, we also have a slightly larger version with an opening of 0.35" for aluminum wired services.
The ECM-1240's main processor will be flash upgradable using the RS-232 port.
We were reluctant in posting too much information since this device has been going through some changes.
If you have any other questions or doubts, please feel free to post them so that I may clarify them.
Paul
