Error on running OneWireViewer -- suggestions?
JimTolbert
Hi, all...........
I am having stability problems with my network, so I thought I would go back to basics and make sure that the OneWireViewer could consistently see all my sensors.
When I try to run OWV, I get one of two situations....
1) I get the screen were you choose the adapater then the screen when you choose the update rate then the screen when you choose the type of sensors to show then nothing! The window disappears and nothing reappears. In the Task Manager, OneWireViewer is running.
2) I get a little error window that says "An internal error occurred ( error code:7)"
Any ideas?
When I run my Java application ( based on Weather Toys ETWS), it seems to run fine, but the sensors start dropping out .. the first one several hours later ( not consistently a particular sensor) and all are gone before 24 hours.
Many thanx................ jt
