The distribution panel is entirely passive
There is one IC on the circuit board. It is in the area of the "common" connection terminal strip. Any idea what it does?
Good catch -- especially for something that has been in the air/error for nine months ... ;-)
The immediate discussion was of the power supply, which is passively distributed (there is no "power gain") through slide switches. The LEDs at each just indicate whether there is power or not but I suppose that some folks would consider LEDs "active devices" because they are semiconductors -- even if they don't increase power.
The RS-xxx signals are also passively distributed (not actively buffered one from another) on the board to each of the eight supported 8870's. If you short together any of the 16 signal pairs all eight TXs or RXs as (the case may be) will go down.
With respect to the IC, I assumed it was to drive the communication status/debugging LEDs. But it is possible that it is a buffer at the input of the board for TX+, TX-, RX+, RX-. (Aprilaire calls these A+, A-, B+, B-) What are the markings on IC ?
The A and B LEDs (which are separate from the power LEDs) should flash when there are communications. They can turn solid ON if there is a problem. To identify which channel/output is causing the issue, the switches are opened for each channel one by one until the light flashes again.
HTH ... Marc
