"Well, I can only speak for my self and my experience with the product"
will the i1 devices absorb i2 extended messages like they do x10 messages?The i1 devices won't repeat any extended messages, but to my knowledge it will not block them, either. So if your i2 device is far away from the plm and you have 1 or more i1 devices in between, it's possible that the extended messages would be too weak to make it all the way from the plm to the i2. (Or vice versa). But if they were closer together, the extended messages might work just fine. As Digger said, the extended messages are generally only for faster programming of the links between 2 devices. All commands to turn on/off and activate/respond to group commands are done with standard messages, and these get repeated by all Insteon devices, regardless of whether they are i1 or i2. Tap-Tap linking between devices also uses standard messaging. And you can still program i2 devices using standard messaging.
The SignalLinks do not repeat extended messages, unfortunately.
Steve,
Are you, or anybody else from SH going to be at EHX?
http://www.cocoontech.com/index.php?showtopic=12335
The INSTEON switches that are shipping currently have not had and paddle or micro switch problems for over a year and a half. There are switches that came out when INSTEON first shipped that continue to work today with regular use. The problem appears to me to be a change of the micro switch from the factory on a small yet significant number of switches that shipped over two years ago. When you said they did not warranty the switches I wanted to make sure that you were not talking about the INSTEON line because they should have honored the warranty. The 2005 and 2006 switches you were talking about were a main part of my product line during my years as an installer and I did not see any significant failures during that time or for that matter even now. My old clients would have contacted me if they were having failures.
P.S. digger, don�t hold back on my account.
SteveL
Steve if you search your own companies forums there are still OLD posts about teh X-10 paddle failures although a lot seem to be removed. I bet if I hunt on Homeseer and other forums I will find them also mentioned.
The products I work with daily use some tact switches and they are expected to last well over 10 years.
We actually recently did an endurance test on an alternate motor in a motorized automated lock. Six samples failed at slightly over 500K cycles. Present issue goes beyond 1 million cycles so we refused to use the motor. That is until it was realized that 500K cycles would last for more than 40 years in a very high use application. So we are re-evaluating again.
The point is that a mfg has a responsibility to do their due diligence to insure that a product has a reasonable life expectancy. Imagine if your car dropped dead just after its 3 year mfg warranty. Would you feel you got your moneys worth?
SteveL
All of my icon relays purchased over a period of 2 years covering both amber and green eventually failed with the paddle issue. Interestingly, non of the dimmers ever failed.
Since the microswitch failure is related to oxidation over time, this test would not be accurate. My low use relays failed sooner than the high use ones.
I had good luck with the Insteon hardware initially and my only real issue is that SH would not spend ANY time or effort to update their SDM and just abandoned development of it, which left any HA software that did not write an interface from scratch out in the cold (and we PAID $200 for this SDK!)
Recently though I have replaced about 20% of my switches due to paddle issues and my PLC just fried again last week. Between Firmware upgrades and failures, I am on my 4th PLC and it is a bitch to replace all of your links since their SDK does not have a delete link command even...
I have felt violated by Insteon for years and now my vCrib software supports ZWave also and if I did not have to provide support for other Insteon users, I would drop Insteon and replace every switch in the house with ZWave. Currently I run about 60% Insteon, 35% ZWave and 5% X10.
Not sure what this thread is even about, but if SH ever wants love again they can update the SDK and complete it. I am a hack of a programmer but I have a full API for my software now... It is not hard, they don't fix it because they sell software and don't want to help anyone they consider competition and that hurts the entire technology.
They should have never written their own software and put that effort into the SDK so everyone else would easily support Insteon and promote the technology, but they got GREEDY and SLOPPY...
Vaughn
www.vCrib.com
I'm not sure if there was a question for me in your post. There have been many companies that have been sucessfull using the same developers process that is in place today. Universal Devices, mControl, ELK, Simple Home Net, ect are some of the companies. Does the developers program offer all of the information that every developer wants?, No probably not. Is all of the information kept up to date with all of the new additions? in some cases, No. If i had spent the $199.99 on the kit and was not happy with the value then I probably would have returned it. If you are looking for specific information that you can not find then feel free to email me and I will do what I can to help you. There is a email address that is on the INSTEON.net website for support and everyone of the emails gets looked at and responded to. SH is working on updating the developer site information daily.
SteveL
