After lots of delays, I'm finally working to move my sensor/detector devices from my old Westec 5000 system over to the new M1G.
First, I've discovered that most of the sensors are supervised with double EOLR's. (1.5K/3K) So I'm replacing these with the 2.2K EOLR's that Elk needs. OK, no problem. I'm only installing single EOLR's. The PIR, Smoke, Heat, CO, etc devices are easy and obvious to modify.
When I opened a couple of the door and window switches I see that they installed switches with integral DEOL resistors. OK, I need to replace a few dozen door and window contacts.
Question: some doors have roller-plunger switches and a few have magnetic contact switches. A wooden sliding door has a magnetic contact switch. Why would the installer choose this over a plunger switch?? On another door a magnetic contact is installed on the latch side of the door instead of a plunger switch on the hinge side of the door. This one I can understand....
Question: Are 3/4" plunger, 3/4" magnetic, and 3/8" magnetic switches all about the same? Same quality? I have Sentrol switches throughout. What brands to folk use and like? I need 'closed loop' or NO switches throughout.
Question: I'm not sure if I'll be installing EOLR's on the door/window contacts that I rework/replace. If I did, what is the best practice regarding how to protect the EOLR's connections? Heatshrink tubing? Or should I invest in insulated wire lead resistors? If so, where would I purchase 2.2K insulated wire lead resistors? The Westec system used (when not having integral DEOLR's), a resistor pack that contains two 1.5K resistors and terminates in four insulated solid wire leads. Can I get something like this that's cheap???
Thanks.
Thanks.
