Hari_Seldon
My new home is under construction and I plan to wire for security, automation, audio and video before we seal up the walls.  We are planning to use spray foam insulation (Icynene) in the walls and ceiling.  I believe as spray foam cures and expands it can get very hot.  I am concerned that this heat could melt the jackets of some of the wiring in the walls.
Does anyone have experience with spray foam insulation? Must I protect my wiring from the heat of the spray foam reaction?
I'd bet that security wiring is probably fine. RG6 and CAT6 may also be as they are mostly used in wall cavities. I am most worried about audio/video cabling (i.e. HDMI).
Thank you,
HS
Thank you,
HS
