Sacedog
Well, I finally got started this past weekend. It took a lot longer than I had anticipated to get to this point, thanks to the lovely City Planning Department. We got started on our construction 3 months late thanks to them. I have never experienced a more bureaucratic organization in my life.
Anyway, on to the good stuff...
ROUGH IN:
I spent time over the weekend doing all of the rough-in. I completed most of the boxes, mud rings, and speaker brackets. A couple of observations:
Let me know if you would prefer me to post pictures here, or if I should just post them to my website, and insert the links here.
ROUGH IN:
- Definitely do your rough-in after the electrician finishes. This is invaluable, as you can avoid all of their wires. They seem to have the philosophy of 'take the shortest path possible, so that we use the least amount of wire....copper is expensive!". Luckily, my electricians are close to being finished, so it helped me figure our exactly where the boxes go. The other advantage is that I can see where the recessed lights go, so I can get speakers placed symmetrically in each room.
- Speaker brackets are your friend. Yes, I know, they cost a lot of money for a piece of plastic, but trust me, they are worth it. There is NO way, I would have been able to get the speakers positioned properly after the sheet rock went up. With all of the trusses, TJIs, electrical, sewer, water, etc. in the ceiling, the task of putting up speakers would be a lot more challenging after sheet rock. The added benefit is that I was able to ask my wife if she liked the speaker placement now rather than later.
- Make sure your game plan is fluid. I spent a lot of time before this, planning out my wiring. I even have a complete wiring plan in CAD, and got a couple of full size plan drawings printed. I found that when you actually go in to set your boxes, there are "things" that may cause you to move them to other locations.
- Bring the right tools! Luckily, this wasn't a problem for me; but for anyone who is planning on doing the own wiring, make sure your have the following for rough-in: Hammer, cordless drill w/ drill bits and phillips head, RotoZip (VERY USEFUL!!!!), tape measure, small level, string, nail puller, pencil, tool belt, extension cord, two ladders. The string is useful for lining up speakers in a room that has trusses going in two directions, or if you need to line up speakers in a weird configuration. The level can be used to get your mud ring at the exact same height as an electrical outlet right next to it (yes, I'm anal, but it is important to me). The RozoZip is a quick way to cut a box in the OSB...my house had a TON of these.
