je1058
I have an OP II and a new house. The HVAC folks advised that the generic T-Stat they installed on the upper level should be changed out to one that provides multiple remote temp sensors and allows averaging. This is their response to the unbalanced air issues I have up here. An example is that one room on one end of the house is quite comfy, while another on the other side is a few degrees cooler or warmer.
The T-stat is in the middle of the upper hall an the plan is to put a temp sensor in each of the farther bedrooms away from this T-stat.
So... Since I have the OP II, I naturally looked at the RC2000, but noticed it only allows one remote sensor to be added. I would love to use this T-stat if possible, but using electric dampers and programming through the OP II to control them and the T-stat based on remote temp inputs directly to the OP II isn't an option, as the HVAC folks advised closing too many dampers while running the system will cause problems with too much volume being forced through closed lines. Makes sense to me.
I looked up an RCS T-stat, the TZ45 and it appears to have 2 remote inputs for sensors and also offers Z-Wave, so I can get it to interface with my OP II. I would like to be able to control my temps via remoted options that OP II offers (touch screens, calling, internet), but would also like my system to be better balanced.
I'm looking for options, suggestions, opinions on this from the pros... Any input would be appreciated!
