18/4 for smokes? No 22/4 fire-rated cable available?
Do hardwired LV smoke detectors possess alarms, or does the control panel signal the horn to alarm? Or both?
Should the sounder output(s), and telco, be connected with fire-rated cable, if they are important to sounding a fire alarm?
Mostly just thinking out loud.
This has been discussed in this forum before....but here we go again.......
The NEC requires type FPL (what you are calling fire rated, or some call fire wire) for smoke detectors. The NEC does not specify a size or color requirement. However, many local jurisdictions require a red jacket and some require size #16AWG. That is why you a lot of FPL in the color red of that size. However, as I mentioned before, the NEC doesn't require this.
Plus another interesting fact is that the NEC allows type CM cable as a substitute for type FPL. CM is regular telephone wire. Most CM is also rated CL2 which is regular burglar alarm wire. So that means that the NEC allows the use of regular burglar alarm wire for smokes (as long as the cable is type CM, which most are).
Now for the other components of the system..... some jurisdictions say that if you have smoke detectors, then everything in the system must be rated FPL. This would include the keypads, power supply, siren, and smokes. This issue seems to be controversial as the NEC language is not very clear on this . However, as I mentioned above, the NEC only requires type CM.
Local requirements vary from the NEC when is come to smoke detector wiring requirements. It is best to consult with your local fire marshall or electrical inspector to find out what your local requirements are.
