I've got a dozen or so of your relay boards, a hub, sensors, etc.  I really like the products, and your support has been excellent as well.
So...as you design future products, I'd like to suggest a board with multiple inputs/outputs, and DPDT relays. Perhaps the DS2408, with 4 relays and 4 inputs. Or DS2406s if they are cheaper.
I'm controlling a bunch of window treatments that operate by switching polarity -- send +/- to open, -/+ to close. To do this, I need to switch two poles, so either I use one of your relays to control another relay, or I'm using other products. With quickly rising energy costs, automated shades can make a big difference, and I think we're going to see a lot more upcoming demand for them.
If DPDT doesn't work, then at least SPDT, since two of those can be used.
For the inputs, including the 10k resistors to +5 will make connecting them much easier. I would also ask for two wiring contacts per input -- the PIO & ground. That way we don't have to bunch wires going to ground.
Last, design in an easy way to mount them. Screw holes are fine. I'm currently using small screws with rubber washers to mount your relay boards.
I hope you like the idea.
Also, I think adding temperature and perhaps light sensing to the motion detector would be great! I may order some temp sensors and see if I can solder them in.
Thanks!
Seth
Thanks!
Seth
