I'm a newby to M1 and Home Automation. I recently purchased a M1 Gold. I had everything installed and began programing. I noticed the system was constantly alerting about a low battery. Not really caring about this situation, because I had the system down for some weeks and never really gave it an opportunity to charge the battery, I ignored the alert and continued programming as time permitted. Finally, the time came to address the battery issue.
I let the battery charge for well over a week with the M1 power switch in the off position. When I turn the M1 on, It powers up and shuts down in less than 30 seconds. I have to control panels (both terminated with unique id's). The primary is off and the secondary just flashes on and off.
I began searching for answer and found all sorts of posts talking about measuring the battery charge. I don't have measuring equipment nor do I wish to purchase such equipment for one-time use. Since this unit is brand new, I don't think I'm having a battery issue. That in mind, I took the unit apart. The thought was lets start from scratch.
I noticed after turning the M1 on I heard a crackling sound right before the unit turned off. The power light is one, the status light is off, and the control panel is off. This occurs whether the battery is connected or not. Note: My test configuration has one control panel only.
Since the status light is not blinking once per second, I think this may be something more than a battery issue.
Any suggestions on next steps.
