Hey all, i have read a number of the posts/threads with regards to garage door openers and home automation systems, but none with these specifics, so i was hoping someone might have some personal experience with these and shed some light? (I am planning to have my garage door installed next week, and need to know if this door opener will work or will another model be more accomodating to what i want to do.)
First off, this is the hardware im planning to use, i have everything besides the liftmaster 8550:
Liftmaster 8550 garage door opener
Omni Pro II security board
HAI Access control Keypad
54A00-1 - mounted outside garage door on fascia with wire going to rack room where omnipro II is located
Liftmaster 8550 push button - located at door to house from garage, this location has 1 LV wire from it to the garage door opener location on the garage ceiling
HAI 8 Relay HAI19A001 - located in rack room next to omni pro II , This location has 1 LV wire from here to the garage door opener location on the garage ceiling
So after reading a few of the garage door threads, i am under the impression that i should have also had a wire going from the liftmaster 8550 push button location to the Relay/rack location... as from what ive read it almost seems like i need to solder the LV wire coming from the relay to the push button connections on the board of the 8550 push button, rather than do anything with the at the opener itself.. when i wired it originally i had expected to just splice in the wires at the opener itself on the ceiling of the garage and assumed that a simple 1 second contact would trigger the garage door to open.
Anyways, i don't have a wire going from the relay to the liftmaster 8550 push button location at the door to the house from the garage. I only have a wire going from the relay to the liftmaster 8550 location on the ceiling of the garage.
I would like to have the bells and whistles of the 8550 and thats why im not 100% happy with just wiring in a basic push button in replacement of the liftmaster one, and honestly if i were to do that i wouldnt need to buy the liftmaster 8550 i could just get another less expensive opener. So if that is my ONLY option please suggest some other openers, but if you do have a suggestion to make this work with the current setup/wiring i have id love to hear it.
I would like for when i type in the alarm code on the HAI access control keypad on the outside of the garage, the garage door opens.
I would also like to be able to open the garage from the push button at the door to the house.
Thanks for any help you can offer.
Reilly
