wuench
Yes they are the middle ground between your typical residential 120V install where you must change out your own batteries, and change out your own detectors every 10 years on a manual schedule and the typical 2-wire/4-wire supervised install where you get an indication if there are issues.
They do have self diagnostic LED's to tell you when you need to swap out individual detectors and batteries. I don't see any drawback to that over running dual installs. You will still need to maintain your 120V detectors manually.
Obviously doing a real supervised install is the best case if you can get away with it....
