RandyKnight
Finally getting around to integrating my irrigation system with the M1 / HA system. I'll likely use mcsSprinklers on HomeSeer but use the Elk for hardware control and have some failsafe type of rules so a valve doesn't stay on too long, only one valve at a time, etc. I've done a fair amount of reading on this already and found BSR's schematic in another thread which was very helpful. But I do have a few questions.
The existing sprinkler timer is in the garage on the other side of the house from the wiring closet with the M1. The existing clock is 24 zones, of which 19 are currently used. There is a single Cat5 run over to the sprinkler location.
Parts I have:
M1XOV (16 output expander)
912-12 (12 relays)
Wall Wart, wire, etc.
So I am short 7 relays and 3 outputs to meet current needs. My thinking was to buy a M1XOVR to give me an additional 8 relays / 8 outputs.
Questions:
1. On the M1XOVR, the 8 outputs drive the 8 relays right?
2. I hate to put a whole DBH out there but with two modules and only one Cat5 am I stuck doing that? My DBH in the wiring closet is maxed out so I'll need to buy one anyway, but I hate to waste all those ports out in the garage. Is there a way to use one port on the existing DBH and then daisy chaing the modules in the garage?
3. Another thought was can I run another RS-485 run from the panel to the garage, daisy chained, bypassing the DBH all together?
4. I also realized this is a good opportunity to automate the garage door openers. Will just an output handle that or do I need relays for those as well?
5. Is there a market for lightly used RainBird 24-zone timers?
Edit: Just rememberd I do have another Cat5 in the garage with 4 unused wires if that helps. It's for the garage door contacts but I could extend those 4 wires over to where the sprinklers stuff is.
Parts I have:
912-12 (12 relays)
Questions:
