beelzerob
Being in the boonies, I've been starving for HD sunday football games since all of the dish and cable companies are bastards who don't include the OTA HD feeds in their services.
So, I went to radio shack and bought a 30db signal amplifier and a 160" OTA antenna. An initial test showed that it was adequate enough....only a few dropouts on the CBS channel, and I get fox, although the game wasn't in HD.
I'm going to put this in the attic, since that will put it up even higher, and keep it safe from weather and lightning, and whenever I can put anything INSIDE the house, I'd rather do that.
The signal amplifier I got has 2 boxes, which I don't really understand...but they seem to work. The first box has "from antenna" as an input and "to power" as an output. That box has no power connections of any kind. The second box has "from amp" as an input, and "to TV" as an output. That box is the one with the power cord and the gain rheostat. So it seems that the first box, without the power supply, is actually the amp.
Anyway....what I'm wondering is how important it would be to put both of those pieces up in the attic with the antenna. I know the general idea is to amplify the signal close to the source, so that you aren't picking up any interference between the antenna and the amp and amplifying those. I'd rather put the plugged-in thing down in the basement than wiring an outlet in the attic and leaving it up there plugged in and unattended.
The distance from the antenna down to the wiring room is probably about 60 - 80 ft. And of course, I'm using RG6QS the whole way.
Do you think it'd matter to the signal quality if I put one or both of those boxes down in the basement instead of up in the attic near the antenna?
