PaulD
Got myself in a box (my fault) concerning use of smoke alarms with Omni Pro II system and am not sure how to get out. Builder wired the house for 2 wire smokes...with my approval since I saw 2 wire smokes supported in the Omni Pro II manual. However, I did not recognize that the Omni only supported the smokes as a sensor and did not provide sufficient power to drive smokes with audible alarm built in. Local building codes require an alarm in every bedroom and it is too late to add any more wire so I am now sitting here with 2 wire to each smoke sensor site and no solution which allows me to tie them to my Omni AND drive an alarm at each site.
Unless someone has an approach I have not discovered, I am facing a situation where I must drive the smokes (with alarm) from a seperate 12VDC source independent from my Omni. That defeates my ability to tie the system to my Omni unless I determine a method to monitor the independent smoke circuit. I don't really care which sensor has been triggered. I just what the ability for my Omni to know that a sensor on the circuit has been triggered so it can take what ever action I have programmed into the Omni.
Side note: The Omni has a load limit of 1 Amp for a group of devices which includes the smokes. Code required the ability to drive all alarms (6 in my case at 130ms ea = 780ma) at one time). That only leave room for 220ma to drive other devices such as consoles and that is not enough to cover all my components. With the new HAI Power Hub, I could offload the consols and create some additional reserve capacity which may allow me to wire the smokes directly to the Omni and that is the option I am looking at if I cannot come up with a less expensive solution.
HELP!!!!!!!!
HELP!!!!!!!!
