There are two primary switch paddle configurations in use today, the rocker and the toggle. The rocker is similar to a typical manual decora light switch but it is 'return to center'. You press the top to turn the light on or brighten and the paddle return to the center/neutral position or press the bottom to turn the light off or dim and again the paddle returns to the center/neutral position. The toggle is usually a flat plate where you press anywhere on the plate to toggle the light on or off, or you press and hold the paddle anywhere to 'cycle' through bright or dim.
The rocker is typically used on PLC type devices like UPB and Insteon whereas the toggle is more used on wireless devices like ZWave and Zigbee. It would seem that either technology could use either type of paddle.
So, the question really is, which type do you prefer - rocker or toggle and instead of picking a lighting technology on its other more technical characteristics, if each lighting tech was available in either toggle or rocker, which would you choose?
I have a feeling Rocker may be popular simply because it is more 'standard', so if you choose Toggle, please make a short post to say why you prefer it.
