Jeff,
If you go the HLC route, you will not have any problems with tracking the status of your lights.
I also started my UPB network through UPSTART. I had all kinds of problems with the OPII keeping up with the actual status of the lights.
I finally enrolled my switches through the OPII (you can now also do it through PC Access) in HLC mode and haven't looked back since then. My lights statuses are always correct.
I only use UPSTART for setting the LED lights and dimmer properties.
As far as links and programming, there is really nothing I have come across yet (at least for my application) that UPSTART can do that can not be done with PC Access.
Ernesto,
Thanks.
Right now I don't really need tracking, I don't use the UPB states as conditionals.
I plan on installing a couple of 5.7e touch pads in the Spring so I'm sure I will want it then (floor plan and light statuses).
I'm looking at the HLC setup and am wondering how well it will track the links.
It looks like the room links are dedicated on, off and levels.
I assume I can't change that scheme at all without problems. Like leave one of the room lights off the levels commands.
For the room scenes, does it track just unit on/off or does it track unit levels?
I have several keypads that do not control lights but send links, usually scenes of several lights.
When those links get sent there is not status sent via the rocker switch since they are not local loads.
I also have several scenes that work across multiple rooms.
Since HLC leaves some scenes free for user customization, I'm wondering how well the Omni tracks the status of these scenes since they are not one of the default actions.
I don't see where you can tell the Omni what units are enrolled in what scenes.
I did have a question regarding the UPB Status Tracking timeout.
From watching the UPB line traffic, it appears the Omni does not poll the units after scene execution in stright UPB mode.
In HLC mode, does the Omni poll all units, or just the ones assigned to the scene?
It seems like there would be a lot of UPB traffic if it polled every unit in a large installation.
If it does poll all units, it seems it would be relatively easy or HAI to enable the status polling under straight UPB as well.
I've got some time before I will need to switch over.
I'll need to look at my current install and HLC and find the easiest way to change over.
What I will probably do is setup a test file in HLC, reconfigure everything, and see how it works.
