icellama21
I know this topic has been discussed before, but it is hard to piece it all together. What are the general steps to minimize the delay for lighting control with an ELK M1 and RS232 controlled lighting interfaces. I know there are some specifics to technology, I'm more interested in minimizing the time between an ELK event(zone change, time, etc) and the transmission of a command from the M1XSP to the lighting interface. I've noticed this can take anywhere from 0.3 sec to 2-3 seconds. Here is what I have seen before:
1) M1XSP for lighting on lower address and closer to M1 on bus
2) Use the OPT flag to limit delay between multiple commands if possible
3) Place event sensors(zones, motion detectors, etc) on fast-loop response
4) Limit the amount of routine work the M1 has to do(like events every second to decrement counters, etc)
5) Use only one lighting interface/expander
6) Using older firmware. Not sure why, but rolling back to 2007 firmware(which came with the system) cut my latency by 50%.
