Sandpiper
I just switched my M1 over from POTS to IP reporting. Everything went fine after I realized the the M1EXP could not report if RP was connected via the local internet. But not a problem...here is where I need help:
I have a RULE that announces whether alarm reporting had been initiated. It makes the announcement when the alarm system is disarmed. If the siren has sounded in the previous arming period, it announces "Alarm reporting has been activated" if signals were actually sent, or "Alarm reporting is cancelled" if the signals were not sent. This can happen (no reporting) if there is a dialer delay or if there is an exit error alarm, and the alarm is cancelled in time.
Now the problem.....with POTS, I used the "line seizure" rule to detect when reporting occurred, but this does not work with IP reporting. Is there an equivalent method to detect when IP reporting has occurred? I could not find one. Any ideas?
