IVB said:
Question for micah/others...
After reading,
The Elk Z-wave module is one of those 'early hardware units with problems' with no resolution yet. I would not recommend going with Z-wave if you plan on using an Elk M1G to control your PLC network.
from jlegault, I'd search a little more into whether or not the Elk Z-Wave module will work as intended. I didn't realize anyone had had trouble with it, but assuming you're looking to add the lighting control to CQC you'll probably want to make sure it will do what you want before purchasing.
Also, I would note, that I have never had issues with auto on/off commands or remote commands not working. The protocol seems to do a very good job at making sure commands are recognized and executed.
However, if all you're going to do is control the Z-Wave switches via a Master Controller, then you should be set. One great feature of the HA07 is that it has built in timer functions to turn lights on and off based on the hour or sunset/sunrise. It's an awesome idea and works well for me to control my front and back outside lights while I figure out how to proceed.
I'd also like to take this opportunity to retract my statement that I am finished with Z-Wave. I didn't realize, until 68string mentioned it, that the units need a minimum load to work and that didn't even dawn on me until I replaced the switch with 2 others I had sitting around that did the same thing. For what it's worth, I had just gotten back from a trip where I buried a cousin of mine and was just pissed that my front light wouldn't turn on. And if you haven't guessed already, my bulb was burned out.
I'm still hoping for a resolution to this and I still think Z-Wave has the best potential of the three new technologies (Z-Wave, Insteon, and UPB) to get the job done and get it done well.
