Hi,
after some time spend in programing, learning and soldering I create Java development environment for manipulation with HB 1-Wire boards.
All source are base on code available on http://www.weathertoys.net and http://www.hobby-boards.com . Examples are tested on 1-Wire network mostly based on Hobby Boards modules.
More info You may found on http://code.google.com/p/sendk/ including source code. All code are available for download using subversion system.
Right now it contains source for searching across 1-Wire network for devices, and example of reading value from HB board Humidity/Temp/Solar,plus some helper class.
All suggestion are welcome, including improvement of source code, more class are coming soon.
Dubravko
Dubravko
