That may be true in an ideal world but there are several manufacturers that don't make outlets, or even 'real' inline modules for that matter. So while a jbox designed relay may not be perfect, it is usually alot better than waiting perhaps years for the product to be designed for your favorite tech. As an example, while SAI makes a UPB outlet, I was not too impressed with it, plus the UPB control is only over 1 of the duplex outlets, plus in some locations you need GFCI so I have several outlets outside that are tapped off indoor outlets in rooms/locations that aren't used or behind things. I simply replaced the indoor outlet with an inline module and used a standard GFCI outlet on the outside. This works great in 2 locations. In another I put a double gang box with 1 regular GFCI and the inline module next to it.Is there such thing as ALC relay (non-dimmer) switches? If so, could you put them inline somewhere, allowing you to control these outlets?
There are, but that is still a "work around" IMHO. The true need is for a ALC outlet. In my specific case, it is a retro job, so it is nearly impossible. But even in new construction, why would you want to have to find a place to put more switches. One of the main purposes in lighting control is to reduce wall clutter, not increase it.
Also, there is nothing wrong with running a hybrid system. I am leaning more and more to doing lighting control with one technology and then other stuff requiring specialty modules, etc with another tech like UPB. And most controllers let you support multiple techs so you Elk or Omni or whatever can easily talk to ALC and something else that has the specialty components you may really want.
