just want to make sure i understand this board. can i attach any 1 wire device as an input and have the network read that device? i have 2 devices attached as inputs, and 1 is powered an one is not powered. both of these worked in a different wiring setup. now, neither of these devices hooked up as inputs is seen by the 1 wire network. i have set the ground dp switches based on if the device is powered or not. and i am using an external power device and have the jumper on . the network is working and reading the devices connected via the j45 plub. thanks
