BraveSirRobbin
Moderator
Yea, my fault, tried the quick and easy way.TonyNo said:Cool, BSR!
Hmm. I can see thumbnails, but I get an error when I click on them.
I linked the full sized images with the thumbnails at the end of my post above.
are you saying you receive different statuses for a sensor within 0.6 seconds? one thing i noticed while i was writing the w800 interface for the app i use is the wireless signal is repeated 5 times. so a ds10a checking in would appear to send closed status 5 times in a row, but never would it send a different status within that burst. i do have an x10 rf repeater which may or may not explain the repeated signals (?) not sure about this as i haven't turned it off & tried to see what happens.Quixote said:I have some of those devices as well, and the W800. The problem that I'm having is that they report their status every hour or so, but often I get a string of open and closed messages within .6 of a second. If this is not an isolated problem, how do you guys deal with this? I can't exactly have sirens set up when my computer is receiving events every once in a while that aren't 100% reliable. The only solution I can think of (that's a bit dirty) is to set up two on each door that I want to monitor and performing a redundancy check.
Thanks for any advice.
Do you have your W800 working as a HomeSeer interface? Did you play with the debounce time any in the W800 plugin setup?Quixote said:I have some of those devices as well, and the W800. The problem that I'm having is that they report their status every hour or so, but often I get a string of open and closed messages within .6 of a second. If this is not an isolated problem, how do you guys deal with this? I can't exactly have sirens set up when my computer is receiving events every once in a while that aren't 100% reliable. The only solution I can think of (that's a bit dirty) is to set up two on each door that I want to monitor and performing a redundancy check.
