There's a few ways to accomplish this, but without knowing the control portion, it's all hearsay at this point. You can install individual T-stats as was alluded to or you could provide a central override as alluded to.
The largest item I can see to consider is whether or not there needs to be a minimum value held and what sort of infrastructure is going to exist and remain connected at all times. I think Honeywell and Nuheat are probably going to be the two most likely candidates. Honeywell would be the equivalent of a direct bolt in, which would allow your end users 100% control (both good and bad)
The other option I could see would be to install a Johnson Controls A419ABC with an A99 remote probe, set your min/max and then connect that/those to a output on a remote controllable system and put that on the network, phone access relays, etc. Part of the benefit here is you would be able to use the dry contacts to put the system to a maximum setpoint you determine, then override and put it to a "standby" setpoint and in theory, your end users don't have access to any of that portion, so Aunt Edna can't jack her heat up to 80 or off the scale.The same holds true where you could also enable/disable the wall mounted thermostats using this method, so occupancy and the like could be added.
