I need a bit of advice on planning a 1-wire network and using parasitic or external power. I already have a 1-wire network running but I've got some issues with lost sensors, bad readings etc. I've put this down to the mix of cable types and mix of topology I used when adding bits and pieces over time.
I have the opportunity to run new cable so I'm going to run a single dedicated CAT5e for all the sensors. I've always used parasitic power (mainly DS18S20's with a couple of DS2423's to be added). If in the future I decide to change to external power, what's the easiest way to do this ?
Is it acceptable to wire each sensor as external (i.e. using 3 wires) and simply ground the Vdd wire at the source or is it better to ground Vdd at each sensor ? I'm thinking that if I do switch to external power at a later date I don't really want to redo the connections on each sensor..
Many thanks
Kevin
Many thanks
Kevin
