Dogman,
Not sure what you mean by "interigate them at the keypad". I monitor mine through the CQC driver for ELK. As I stated earlier, it may take anywhere from 1 to 10 seconds for ELK to see the changes done at the keypad, but eventually does.
Are you using ELKRP to see the status? That should also be able to tell you the same thing.
George m
I mean when I go to the Keypads and go to lighting and scroll through the lighting functions I can see all the nodes but their status is not correct. I can control the lights from the keypad ie turn them off or on or set a dimming level and they will respond. But the status of the lights don't seem to update when either a rule sets the lights or I manually change them locally. Even after many minutes. I only have about 14 nodes in the entire system. Occaisionally the status at the keypads will be correct but not very often. Oh and by the way when I use Luminlink it does pick up the status changes and shows them correctly.
Ok I am new to all of this including the ELK RP. I see no fields in the lighting tab that show the status of the device. The only fields availble in the lighting tab of my RP version 1.6.26 is Name, Format, Type, opt, show, and Voice description. I fully admit however I am a newbie and am stumbling through this stuff so maybe I am missing an option setting somewhere to see the status.
