BraveSirRobbin
Moderator
Yes 2.5 Kohms sounds high. Are you sure you put 2.2 Kohm resistors in all the zones, because I believe (don't have any in front of me) that those EOL resistors are 5% tolerance which would put their max reading at 2.31 Kohms. Add 3-10 ohms for wiring and you are still off of your 2.5 Kohm bad zone readings.
Also, eight volts is the max for a non violated zone. I don't use EOL's myself but I'm wondering about your 7.3 volts for a good zone as I'm surprised that is so close to the upper range (between 4-8 volts represents a 'good' zone in it's normally closed state).
Can you take some voltage readings? Put the meter in AC voltage mode and read the wall wart of the Elk's input into the M1. This should be 16.5 volts AC.
Then put it in DC and measure an aux output.
I'm wondering about the M1's reference DC voltage.
EDIT: Just read the manual and 7 volts is the nominal non-violated zone voltage for an EOL normally closed zone.
The three zones states are:
Shorted (Trouble): 0-3.9 volts
Normal with 2.2 KOhm EOL 4.0-8.8 volts
Open 8.9 - 13.8 volts
